Hi Sony,
Pls help. I bought a new Sim for my Sony Xperia M4 Aqua but unfortunately, it is Sim Locked. I've checked the counter and it is blocked.
Network 0
Network subset 0
Service Provider 0
Corporate 0
Sim 0
What will I do to unlock it?
Thanks...
Hi @ChrisjohnNased, welcome to our forum!
To have this counter reset, the device will need to be sent to an authorized service centre, so I would recommend that you get in touch with your Local support team and they can either assist you with creating a service order, or provide you with information of the closest authorized service centre where you live.
I hope that helps!
Thanks...
@ChrisjohnNased, you're very welcome and I understand it's no fun having to send in your device to service directly after you bought it.
