I have recently updated my Xperia MP4 Aqua (E2303)
When I want to since my phone I have to switch on press the audio button select the drop down arrow and move the 3 sliders to "0" and then remember to do the reverse to but audio on.
Can I revert it back to the app that gave you a silence everything for a given time .
Ta
WxAx
Hi @WxAx, welcome to our community!
It works a bit different in Android 6.0 when you want to turn on the Do not disturb mode compared to Android 5.1.1 and you can either do it from the quick settings on your phone and by pressing and holding volume down until it goes to 0 (vibration) > press once again and you will enter the do not disturb mode.
Let me know if that helps!
