Yes,I thought it was otherwise,but it does not matter.Probably just telling you the update is available via pc companion.
If you already have the update,you should not update to it anymore.It might make more bad things than good.
You could go to update centre and remove the update.
No known reason,probably the update was on your update center and when you connected to wifi,you got the notification.Or it could just be a bug,you could go ahead and update...
Yes, same here. Keep getting notification msgs and pc companion keeps telling me I have an update but it is impossible to connect and same with sus. Loaded by wifi no probs and both pc companion and sus were impossible to load before that too. I must have wasted hours trying to downoad these software updates by pc and it never works :smileyshame_on_you::smileyconfused::smileyangry:
But you already have the update,right?
