how can understand that my xperia m4 aqua duel is real or fake
Hi @joyu,
Welcome to the forum!
If you add your IMEI-number to your account or if you send me your IMEI-number in a PM I can take a look at it. To find your IMEI-number either enter *#06# in your dialer or look under Settings > About phone > Status > IMEI.
Hello, I am Irakli from Tbilisi, Georgia. I have Xperia z3 dual. I am not recieving any updates since I bought it (02/2016), so I wanted to check IMEI. I've checked it with http://www.imei.info/ but it does not recognize. I've checked with another site: http://www.gsmcamp.com/check-imei-esn-lookup/ - and it recognize as MOTOROLLA V3.
Please, can you check it is it really fake?
Hi Didik
i am also experiencing the same issue as@Joyu
I have been having problems with my Sony M4 Aqua from the first day i purchased it. on the fist day the phone heated up excessively and did mnot switch on and i took it back to the store i had bought it, waited for 3weeks to findout it had a factory fault, they gave me a second Aqua which seemed to work until recently the screen becomes black cant view anything but the phone is functioning, my speaker is not working i have to use earphones to pick up phones, the flash of the camera stopped working aswell, and might i add the quality of the pictures is not the same as other M4 Aqua;s ive seen , mine is blurry and the pictures are faded. I bought the phone in August 2015 and it hasnt even been a year but already im experiencing so many issues. im very disappointed!
My imei number is
please check if its real or a fake
@joyu wrote:how can understand that my xperia m4 aqua duel is real or fake
I need to know if my sony xperia m4 aqua is an original
Hi @Partson1234, you can send me a private message with your IMEI and I can have a look at it.
To display the IMEI number in your device, open up the dialer and type in *#06#.
Thank you and have a nice weekend!
