Hello Everyone,
I have a question, i'm almost buying new microsd card but i want to know what type of class is accepted to xperia m2 dual (non aqua)
Thanks!
If you plan to use Full HD recording a lot, I would recommend at least class 6, but to think ahead, you can get class 10 and use it with any other newer device.
I'm thinking buying class 10 just wanted to know if m2 dual accepts sd cards with class 10
It should accept.
