Translation via Google Translate:
Before updating my xperia m5 everything worked correctly but then it was updated to ver 6.0 and only to given problems The hour does not advance it gets very hot it gets slow which thing should not happen because the ram is 3gb and it does not last long the stack all enpezo by the ver 6.0
Antes de actulizar mi xperia m5 funcionaba todo correctamente pero despues se actualizo ala vercion 6.0 y solo a dado problemas La hora no avanza se calienta mucho se pone lento cosa que no deberia de pasar porque la ram es de 3gb y no le duro mucho la pila todo enpezo por la vercion 6.0
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
It's strongly advised to perform a software repair using Xperia Companion after major updates. This will do a clean installation of the latest firmware and will also wipe your internal memory. Don't forget to backup using Xperia Companion, but preferably without adding apps or settings to the backup.
