Hi
I have problem with using of GPS. When I am using my endomondo it fixed the location, but after few minutes it just loses the gps signal on the open road under clear sky and looks like it remains in search mode. It never fix position again. I need to manualy disable GPS. And after enabling it will fixed within few seconds. Unfortunatelly this problem occurs randomly and always I have to do this GPS disable/enable procedure. And this is really annoying.
Similar behaviour happen with other software like Sygic navi or GPS test
Is there any help? New firmware? Anything?
I am using Xperiam M Dual
model c2005
android 4.2.2
kernel 3.4.0
build number 15.2.A.1.12 (latest in our country)
Thank you
hoped after update to 4.3. gps will be fixed too, but still not working properly.
Looses connection and let me hang without orientation in the jungle.
As a navigation in car, its unusable (google maps).
I have the exact same problem and have noticed that removing any covers from the phone drastically increases gps signal.
Basically i could never signal indoors, which I thought was normal but after removing my cover I get excellent indoor signal according to Endomondo
I think I've found a solution:
1. Latest software: 15.4.A.0.23
2. Turn on everything in Location Services
3. Use some app that constantly measures satellite signal strength (for example 'Satellite Check') thus preventing GPS signal loss
4. Open your fitness app after the signal stabilizes
I use it for mountain biking and last 4-5 rides everything's ok.
This is a hardware problem, GPS antenna is too weak...
I returned my phone to Sony UK for repair, hopefully the phone will be returned with fully functioning GPS (if not I will be requesting a replacmnt unit / model).
@MarekJuju wrote:I think I've found a solution:
I can confirm the method working also with Jellybean 4.1 as I now managed to track 50km successfully during cycling.
@cwthomas wrote:I returned my phone to Sony UK for repair, hopefully the phone will be returned with fully functioning GPS (if not I will be requesting a replacmnt unit / model).
Good luck, Sony don't care. I went through the exact same process only to have my phone returned to me last week with the GPS still not working (I think all they had done at the repair centre was reset the phone and maybe install a newer version of jellybean 4.3). I then phoned Sony to complain and they said all they could do is a manufacturer's repair under the warranty, which is what I just had had the phone returned from! Useless. Basically, as I explained to the Sony customer services lady, this is an issue (unless the poster above is correct which I don't beleive he/she is but I will try the fix all the same just to see) with android jellybean 4.3, which people have been complaining about for ages on google support forums (https://productforums.google.com/forum/#!topic/maps/GAiqqqTlbIY%5B1-25-false%5D)
@cwthomas, keep us posted on how you get on asking ffor a replacement as if you manage to get them to give you a replacement model not on Jellybean 4.3 I will get them to give me one too.
I came acros another possible fix here (http://www.askstudent.com/how-to/solved-searching-for-gps-issue-on-nexus-4-or-android-phones/ - look for Matt Hill's comment in the comments at the bottom of the page), which I've just tried tonight so I'll feedback to say if it works.
The most important question is IF and WHEN Sony Xperia M will be getting kitkat update. Does anyone know, a poster on these boards seems to think it will be sometime this year (http://talk.sonymobile.com/t5/Xperia-M-M-dual/Sony-Xperia-M-Going-To-Get-Android-4-4-Kitkat-Soon/m-p...
My phone arrived back today, GPS still not working, presently en route back to Sony - decidedly unimpressed by the service from Sony so far....
Good luck, Sony don't care. I went through the exact same process only to have my phone returned to me last week with the GPS still not working (I think all they had done at the repair centre was reset the phone and maybe install a newer version of jellybean 4.3). I then phoned Sony to complain and they said all they could do is a manufacturer's repair under the warranty, which is what I just had had the phone returned from! Useless. Basically, as I explained to the Sony customer services lady, this is an issue (unless the poster above is correct which I don't beleive he/she is but I will try the fix all the same just to see) with android jellybean 4.3, which people have been complaining about for ages on google support forums (https://productforums.google.com/forum/#!topic/maps/GAiqqqTlbIY%5B1-25-false%5D)@cwthomas, keep us posted on how you get on asking ffor a replacement as if you manage to get them to give you a replacement model not on Jellybean 4.3 I will get them to give me one too.
My issues are pretty much the same as those explaind in the 4th post on page one of this thread, I reckon this issue relates to the Xperia M as opposed to 4.3
Reading through this thread makes for pretty damning reading re so called 'support' from Sony, they appear to have been aware of the issue for a number of months and for whatever reason are failing to rectify - it should not be up to the customer to find 'work around' solutions - the product should work straight from the box.
I'll see what the the next week or so brings, in the meantime if someone from Sony could post the email address for the deparment that deals with complaints it would be appreciated.
Noone from Sony will comment on these threads, I've made them aware of the threads several times, they just do not care. I don't think it's an Xperia M issue, if you look at the first link in my previous post you'll see that the exact issue has been occuring across a vareity of devices all sharing one commonality - they are running jellybean 4.3. Sadly the Xperia M is the only phone that meets all of my needs, otherwise I would have made a chargeback request with my credit card provider, gotten the money back for my phone and bought a differernt phone and as a result of the standard of customer service I've recevied in this case I will never buy a Sony product where there is a suitable alternative and I will also advise my family and friends to do the same (no wonder the company is going down the pan - http://www.bbc.co.uk/news/business-27234511). Fundamentally this is a Google/Android issue in that they've released an OS with a faulty GPS and have done nothing to fix it, despite countless numbers of people complaining to them (again, see the first link in my previous post). Unfortunately this is what happens when virtual monopolies arise, I mean what else are people who can't afford whatver it is for an iPhone £500-600, going to use? A windows phone or a blackberry? Hmmmmmm......
