my phone got the update and after the error, the sim does not work.... search operator, operator ok, sim dooes not singing with operator. Other sim card it´s ok, only T-mobile problem.. before update sim ok. android 4.4.2
Phone - restar, factory reset, reinstall over pc...no change error...
Please, Can you help me? 😞
I think you should try to change network mode to GSM only and see how it is.
