Is it possible to keep screen off and prevent randomly predefined text message sending
At least keep screen off during incoming call when headset plugged in or SBH50 headset paired.
I love bike ridinig. My xperia goes with me every time. but i couldnt answer single incoming call yet. Phone ends call or sends predefined sms. Every time when i have call i have to stop my bike get off carefully take phone out of my pocket and answer it. its so annoying
P.S. English is not my native language i hope i could post what i mean.
Appreciate your help
Good day,
I experience that after an incoming call was received and answered the Ring volume is set to low.
I try to make sure that I don't touch the volume controle key. I thought that I might touch the down key for the volume.
It seems as if it just happens when a call was received and not on making a call.
Any suggestion on what this might be or how to resolve.
It is a iritating to everytime after a call check the Ring Volume and having to increase it back to my prefered level.
Thanks,
Alfred
Try an app preferences reset - Settings then Apps then tap the 3 dots then Reset app preferences then reboot and test, Take note that ringtones etc will revert back to default
Smartphone sony xperia z5 dual ....waiting for your reply
I have a problem with Sony M4 Aqua, Incoming calls ring twice from the caller before ringing on my device. There is +-3sec delay
2015-07-20 11:34 PM
I have the same problem. I don't need this function and I want to disable it, how can do that?
