Guys,I give phone Pawnshop.i m back phone, and see option memory.my memory amount to information diagnostics /data 4gb.It's right? Shouldn't it be 8. It seems to me that the memory module was stolen one. Tell me please
I doubt a pawn shop has the required hardware needed to swap out a storage chip to be honest.
These chips are surface mounted and need a very expensive SMC remount machine and the solder pin layout for that particular model.
You're talking tens of thousands of pounds/euro just to take 4gb from a old model mobile, not something I think a pawn shop would have.
What is more likely is that your OS is showing "available" storage instead of total storage.
Thank you for the answer. This model should have 8. and after the delivery I noticed a slowdown and no freezes before. Do you have a good program for viewing your hardware? And is there a program for checking the authenticity of installed components? Thanks again and good days.)
