So i bought this phoen 10 days ago. It surpirised me that only after 4-5 minutes of using it it became exageratly hot. So 3 days ago i updated the o.s. but the problem didn't go away. I had smartphones even from theyr begining and never encountered such a problem that escalades so fast . I mean i never get the passed the 5 minutes video recording time because the camera app. shotsdownd due to overheating. same goes for data connection and i don't even want to talk about gaming o better yet gaming online( i am a Hearthstone fan and i never got to play more than a game due to overheating). The phone becomes unbearably hot that I cannot hold it in my hand and i close whatever i do because of the fear of damaging it permanently. I understand that this is a waterproof phone Sony but please don't make us use it all the time submerged. Hope u solve this problem soon.
Settings > power management > battery > which apps are using up the battery, it could be play services, do you have an antivirus app or taskillers?
The most battery goes to the display, atenna and so on. Play services only covers 9% of the consumption. I only have the antivirus that was preinstalled and no taskillers. As i said the phone is new and i have 4 aps installed one of which is a game and the rest are activation dependent not background functionality.
This is what I would do
Repair the phone with PCC > uninstall any preinstalled antivirus apps > restart the phone > play store > settings > uncheck auto update > restart the phone > report back in 4-6 hours.
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
And 60 Celsius is ok for a plastic phone? How long before all that heat damages the nearby pieces? Is not ok is a fault in the Snapdragon 600 series that needs to be repaired with an update.
I did all that u sugested and the problem is still there.....I am begining to feel sorry i bought this phone..
Hi Qaisarshah, welcome to the community!
Are you using the phone while it is charging? If so, what are you doing on the phone?
You could try running a software repair on the handset with PC Companion to see if that helps, you can back up your phone first by clicking Start under Backup and restore and then when that finishes go to Start under Support Zone > phone/tablet update > repair my phone/tablet > continue to follow on screen insctructions). If this doesn't help, you can then contact your local Xperia Customer Care team.
