I've only had this phone for 3 weeks and now have no sound at all on anything, utube, music, ringtone.etc.
I have checked settings, Restarted it, done system reboot in safe mode etc. It does not work with headphones either....any ideas please?! Cheers
Topic edited by Rickard
Hi @HippyChic
I suggest you to first run a backup of the device information like this:
http://talk.sonymobile.com/t5/FAQ/Backup-amp-Transfer/m-p/407253#U407253
Try performing a system repair using PC Companion:
http://support.sonymobile.com/gb/tools/pc-companion/
This will factory reset your phone and erase all data. You might need tocharge your device for about 1-2 hours before so the device has at least 80% battery. Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device). Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process. If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP.
I hope can be useful.
I'm at disposal for any question.
Best Regards,
My phone doesn't have any sound such as ringtones, alarm, vibrate etc. It was totally silent. But if i am using a earphones it was loud and clear. It's been 1 week and i don't what to do please someone help....
