- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
No ringtone on incoming calls
Since the Lollipop update, I have, on 4 occasions this week, come across the same problem.
When there is an incoming call, the phone does not ring, I only see the screen and notification light turn on.
Phone volume (using side keys) is set to the maximum level for ringer. I go to Settings->Sounds to select my ringtone, and try calling my phone again but each time it remains silent.
When my calendar has notifications, I hear the notificaiton noise for events.
The only way to remedy this each time was a reboot of the phone - after this the ringer would work again, at least until the next time it goes silent.
Any idea what could be causing my phone to remain silent for incoming calls ?
Topic edited by Rickard
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Before I used lollipop I faced auto off n mic problem it was solved nw facing new problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Since one year
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try do diagnostics in setting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Earspeaker ------failed
Microphone------failed
Dis is the result
When I restart my phone
It resolves
Daily twice I am getting dis problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I didn't get ua word safe mode
And I'm using normal apps me nt using any new apps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Safe mode is a mode where all downloaded apps are disabled. See this link for information on how to set your phone to safe mode: /t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
This is a good way to see if it's caused by the phone or one of your apps.
It might be that you have an app that is not fully compatible with Lollipop. It's something we've seen before so it would be good to check if that's the case for you as well.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Will try n let u know
