I recently bought me the xperia M4 aqua dual and configured the Myxperia service on the device. After day 3 I restarted the M4.
As the M4 was started up the MXTP gave me the lockdown screen with the verify, wifi settings and emergency call options on it. So as I wanted to unlock my device i pressed the verify button and a log in screen for my google account appears. I use my google account on all kinds of different devices so I logged in. But here someting goes wrong.
When I typed in the username and password to verify it is my M4 it gave me a loading icon for 2 seconds and then it says "incorrect username and/or password" and my M4 stays locked. To double check if my password and username are correct i logged in to another adroid device and my laptop with no problems. So now I'm stuck with a brand new non working xperia M4 and my hope for a good working security system is all lost.
Thanks Sony.
I am also facing the same problem, I restarted the phone, and it got stuck at the protected screen. I tried with the registered gmail Id like 100 times but in vain, I software repaired the phone from pcc, but still same protected mode, I deleted the device from the my xperia list by accessing the account from PC, but still it is locked down,Sony service centre is 400 kms away from where I live, It is really diffcult for me to go to service centre, Is there any way by which the phone can be unlocked online. I have great expectation from Sony, I am great fan of sony xperia phones, But this time I have become fed up, please help Sony.
I have also heard Sony is working on a fix, it will take 1 week or so, Is it true, then I will wait for the same, Kindly confirm please
Well, I'm also facing the same issue with my M4 Aqua. After a reboot it entered lockdown mode and now I'm stuck since it won't authenticate my google account. I can find the phone on my computer via myxperia but it only says "Protected".
@Johan kindly reply
SOLUTION / EDIT: It seems there IS a way to escape the lock caused by MXTP.
You have probbaly updated all the apps on your phone right after you set it up. It is quite normal to reboot the phone after installing a bunch of software, after all old Windows habits die hard. Unfortunately, It seems that MXTP hates updates.
You should also reboot to make sure it worked. I could also have been lucky, I can't promise it will work for everyone. It's certainly quicker than repairing through PC Companion or other flashing software.
From what I can guess, MXTP does not seem to work with the updated versions of various google services, and will only work properly with the version it was shipped with. Services like Android System Webview may also be the culprit here, since MXTP does open a web page internally. Hope this helps @Johan and the rest of the support staff.
OLD POST:
I Bought an M4 and had to get it replaced the next day for a faulty mic. A week later I got my replacement and set it up. Then I just rebooted ONCE and now its stuck on the "Protected" screen because of MXTP. I am certain without a shade of doubt that I have full access to my google account and the information I am entering is correct. The phone can be tracked/ringed on the my Xperia website. It is even running all my applications in the background WITH THE SAME GOOGLE ACCOUNT. This is ridiculous. Preferably, I do not want to get another replacement, please help.
I have tried the above method, it is not working for me
AniruddhaHars solution worked for me! :smileysmileythumbsup: Thank you!!
And I will never never never never never activate this stupid function again on my phone!
i got the same problem from yesterday, gmail is working, password is correct but could not able to bypass the restriction. screw you SONY first device was damaged now this things.. I'm gonna throw your all products out of my home and i will tell my friends and relatives to not buy your products ever.
Any update on the matter?
As of yesterday I'm experiencing the same problem on a m4 Aqua Dual.
If only I read this page before I activated MyXperia...
