Hi
I am a fan of SONY and I know that most mobile phones of sony has usb host (otg) functionality
I am waiting for the M4 aqua dual (LTE) to be my next phone. but i have a question. is this phone has otg support?
in the backup and restore section of the manual of the M4 Aqua has written that :
"With this application you can back up the following types of data to an SD card or to an external USB storage device that you have connected by the USB Host adapter to your device"
but if you watch this video, it says that it has not otg functionality
http://www.youtube.com/watch?v=9tEENBT0U5Y
so, is this phone support otg or not? please explain completely.
if you have a retail one, can you test it and let me know?
thank you
Solo quiero saber si mi teléfono es compatible con un Usb o saber como puedo llegar a saber si mi dispositivo es compatible. Gracias.
I just want to know if my phone is compatible with a Usb or know how I can find out if my device is compatible. Thank you.
GT
با سلام میخواهم گوشی من USB otg ها را ساپورت کند چه کاری باید انجام دهم
باتشکر
Hello, I want my phone to support USB OTGs. What should I do?
Thanks
gt
