I just bought a new M4 aqua phone.
Now I am looking to buy a new Micro SD Card for my phone.
I saw online that their are many speed specifications availaible for micro Sd cards, i.e. class 10, UHS 1, UHS 3 etc.... with Read/Write speeds ranging from 30Mb/sec to 95 Mb/Sec.
I wanted to know what is the maximum possible Micro SD Card speed supported by M4 Aqua?
I know that the maximum memory it supports is 128 Gb But what is the maximum possible speed SD Card that I can instalkl in M4 Aqua.
Regards
Yuri
Xperia M4 Aqua supports 128 gb MicroSD cards and will be able to use any class/UHS class. We do however not have any specifications on what speed the phone supports but for example when transferring files from a computer the higher class the better, as the speed increases.
@YSeekingAlpha There is no need for such a fast microSD on a smartphone. 4K recording (which M4 doesn't support) requires at least class 10 microSD. So you are fine with class 10,perhaps UHS I.
If you need further information,contact your local sony team:
http://www.sonymobile.com/global-en/support/contact-us/
I just test the external sd card, It's read/write speed is both limited to about 40MB/s.
(tested by A1 SD Bench & Kingston SDCA10/64GB)
So, it seems to be not supported the UHS-I 104MB/s, but 50MB/s.
And we still can use a better card for the writing speed.
Was looking into getting a SD card for my new phone and when I popped open the slot there was a paper in there. Grabbed tweezers to pull it out and it gets stuck near the end. I tugged on it a tiny bit but I don't want to break it and have a piece floating in my phone. BASICALLY i was just wondering if i should go ahead and rip it out or if i got some factory warrenty/safety garbage on my phone...
Mate the sd card slot for xperia m4 is bad
The spring that clicks in my sd card is ruined from a slightly larger sd card.
You need to find a sandisk card that is thiner and it will fit. If its not too late
UHS micro sd cards not compatible? And this comes from an official Sony reply? Pffffff
I use a Samsung Pro+ 32gb micro sd which is UHS-3 and it works just fine.... Get it together with your products Sony...
