Hi sir/madam,
i have a problem. when i listen music from sd card then music could not play clearly.....sometimes it breaks....but when i listin music from online or youtube then it play clearly......my sd card is class 10......besides i have changed my sd card which is also class 10....but the problem is sitill now...........................what is the solution????
please reply..................:(
Are the terminals clean? Are you Transfering from a PC? Maybe the distortion is coming from the PC. Noisey Power Supply for example.
Solved......:)
i soved that problem by repair my Android operating system (sony pc companion)
feeling great
Great.
how to do the sony pc companion? can you give me the instruction? i have the same problem with you. thanks.
