How can i get the imei for m5
Hi @josh66, welcome to our forum!
As @Quester mentioned you can find this information if you type in *#06# using the dialpad in the Phone application.
There are three more ways as well.
1. Check the box which the device came in.
2. Open up the SIM/SD card slot and drag out the little white paper, there you can see the 15 digit number that starts with 35.
3. Settings > About phone > Status > IMEI information.
I hope that you are able to locate the IMEI number using any of these four different ways!
