I want to block incoming calls when I am roaming, and to do that I need to enter a password. But the thing is that I don´t know what password it is. So is there any way to reset that password?
Just like mentioned before, it is the service provider that you need to contact. You need to ask them for the PIN2 code:
http://support.sonymobile.com/global-en/xperiam2aqua/userguide/Restricting-calls/
For that password you need to speak to your network as it is them that provide that info
But I have speak with the network administrator and they told me to contact the manufacturer of the telephone. But I don´t know if they can help me.
