I have Xperia M2 with android 4.4.4 update. My mobile vibrator intensity is very low, When it rings for incoming call. I dont feel
it like my old xperia mobile. Pls tell me how increase intensity of vibrator for call alert.
ThnX
Nothing I can do about that - You could try a 3rd party app but not sure if they will increase the strength or just change the vibration pattern
Sorry but this can't be done and for safety if you were to change the code via a rooted phone then the phone could become damaged due to applying to much power to the motor
Ohh, but really vibrator intensity is very low in M2.
ThnX
Yes i tried 3rd party apps but it change only patern not intensity.
