We have now started rolling out a new version of the firmware, 18.6.A.0.182. This update contains a fix for the GPS so please update your phone when the update is available for your unit.
Can you go to Settings -> About Phone -> Diagnostics -> Test -> Run GPS test?
I have the exact same problems with my m2 aqua and latest update
Restart didnt solve anything..... After so much waiting for the rotation fix now the navigation system is useless....
I have no words....
I confirm the issue with GPS, on Yandex Navi, Google Maps, AndroiTS GPS test free, Ingress - all apps are mistake GPS coordinates.
From 20 attemtp 1-2 is correct. In use this apps after lock/unlock screen GPS coordinates is change but changes coordinate is not correct too.
the time of whiting coordinate or my speed isnt relevant.
Any comment, SONY?
