only had this phone a week and its just dead. it was working fine one minute then screen went blank ive tried turning it on but its not responsive , tried leaving it on charge over night still nothing there is still a red light flashing but when its plugged in to the charger its not doing anything tired the on button and volume up but nothing help? or will i have to go back to carphone warehouse ?
This is what I would do
Remove both SIM and SD cards > connect the phone to a wall charger > press and hold power & volume up for 15 seconds > let the phone charge for 3 hours
Have you dropped your phone or exposed it to water?
does it has a protective film or case that might be blocking the proximity sensor?
You could repair it with PCC
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
nope never been exposed to water.it hasnt got a case on it but it has a protective layer on the screen ?
okay then do what ?
still just flashes red doesnt stay on constant or say its charging
