Hey.
I am using Xperia M Single SIM (C1904) and I saw that new 4.3 update was realsed for Xperia M Single SIM but there was showing single SIM Model number is C1905. Can you please explain why showing like that?
The update is being rolled out for both C1904 and C1905 right now. But as usual the update is done gradually for each country and operator and may need local and operator approvals before you can update your phone.
The difference between C1904 and C1905 are what networks they support.
C1904:
UMTS HSPA+ 850 (Band V), 1900 (Band II), 1700 (Band IV), 2100 (Band I) MHz
GSM GPRS/EDGE 850, 900, 1800, 1900 MHz
C1905:
UMTS HSPA+ 900 (Band VIII), 2100 (Band I) MHz
I am from India and I tried via Sony PC Companion and I cant even find.
I think need more time!
Thanks for your support!
