Hi
Does anyone know if the M2 supports things like the STM-10 which use a 5-pole jack, rather than the 3-pole normal one?
Thanks
Hi @Horatio,
To my knowledge Xperia M2 does not feature a 5-pole jack which means that the STM-10 will not work with it.
From my knowledge, it doesn't support 5-pole jack. In the manual, is not specified. On the STM10 oficial product page, is mentioned this:
Compatible
Hi @Horatio,
