How old is your SIM card? reinstall the latest update with PCC and report back
Bridge (for Mac)
Alternatives on How to backup Xperias
Bridge (for Mac)
Thamks for your answer. Finally i got it solved. Only when i made the 3ª hard reset but this time with the "backup data" settings turned off and the "Automatic restore"turned off in the same settings, it worked. I think some aplication update was causing the problem and it is happening in a lot of M2 devices. It is a shame that we can't downgrade the apps frm the store. Thanks.
You should send that feedback to Google, I'm glad your phone its working fine now
