Ich kann meine Einstellungen nicht öffnen.
Wenn ich in meinen Einstellungen etwas ändern möchte, erscheint ein Fenster: "Leider wurden Einstellungen beendet" was nur mit "ok" annehmbar ist
Hello,
I can not open my settings.
If I would like to change something in my attitudes, a window appears: "unfortunately settings were terminated" which is acceptable only with "ok" - GT
Hi @Verena0, sorry to hear about this.
Your question has been translated to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
Try and restart your device in safe mode and see if you are able to open the Settings application when downloaded applications aren't loaded.
If you are able to open up the application while the device is rebooted in safe mode, go to Settings > Apps > tap the three dots in the top right corner > Show system. Scroll down and find "Settings" > tap on it and choose "Storage" > Clear data > OK and restart your device.
Try opening the Settings application in the normal mode now again.
Let me know if that helps!
