I'm having a range of problems with my sony aqua charging. Sometimes it will charge ok for 5 minutes and other times it will say it has 10 hours to charge! It will also randomly make a noise (as in the charger has just been plugged in, when the charger hasn't moved. I have tried other chargers and the same happens. Any help will be gratefully received.
Also sometimes when on charge all the top icons will flicker. Ive tried safe mode.
Hardware problem. The usb socket is loosy. Use a clip when charging
