Good night, I would like to be sent as specifications of the sony xperia m5 charger, what is an amperage? thanksHi Lorena3,
Depending the market (country) you may get different chargers, if we assume you got the classic UCH20 the ouput is 5v/1500mA.
Hi @Lorena3, welcome to our forum!
As @YoGem pointed out, the charger that is included together with the phone may vary between markets. I'm situated in the Nordic market and charger that is included with the Xperia M5 here is the EP800 which has the following specifications: Output 5.0VDC = 850mA (VDC=Volts Direct Current, mA=milliamps).
I would recommend that you get in contact with your Local support team since they are the experts on your market and will be able to provide you with information regarding which charger is included with your phone.
Let us know how it goes!
