Hi. I have a problem with my M4 Aqua.
When I changed charging port, power and volume buttons don't work. These things do a camera button. I dont know what is going on,and where to look answer. Thx for helping guys.
perhaps when the phone was repaired it wasn't properly reassembled which is causing this problem. If Sony repaired your phone, you should contact them so they can inspect the device, if not, then you could DIY or contact Sony, but it's highly unlikely that they will inspect the device as someone else repaired it.
