sir
one more thing i want to ask is that, i just checked that sony companion is showing an android 6 update for my device, while the settings option and the website (after asking IMEI no.) is saying my phone is up to date (current version of my phone is " 26.1.B.3.109 " ), so can i update my device through sony campanion.??
or what do you recommend as i am seeing that many sony owners are facing some software glitches and problems after updating there phones to android 6(Marshmallow).?
What will you suggest.? Should i upgrade it to marshmallow or wait for an month or to.??
i am a bit worried because , when i was about to start the update in Xperia Companion it was stating that, i wont be able to go back to the older version after updation
i am in a dilemma , please help
man , if anything wrong happens to the device it won't void itz warranty , right.?
i dont wan any risk man
Updating your device through the official Sony Mobile software (Xperia Companion) will not void your warranty
thanx guys
while repairing my xperia m4 aqua , itz automatically gets me to the marshmallow,
and m quite happy with the newer version
as heating issues and battrey drain problem is almost solved,
bt now i am facing a new issue ,i.e speaker is not working now, with some apps media volume doesnt work, sometimes it doesnot rings on calls, and today even while playing a song i've faced the same issue, . every tim i have to restart the device to make it work, but i cant do this restarting thing all d time know,
please help me
