Hello! I do not appear on the calendar, I have tried everything and there is no way. Any solution?
Hola! No me aparecen en el calendario, lo he intentado todo y no hay manera. ¿Alguna solución?
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Settings > apps > calendar > enable
I have it enabled
