Hi! I have here a screenshot of my camera screen. My screen is okay but everytime I use my camera, I see this. It's like it's divided into a dim part and a lighter part. Can you help me why this is happening? Is it because my camera lens is dirty? It was okay a week ago and then suddenly, this happened. I would really appreciate if you can help me with this. Thank you so much.
You could try cleaning with microfiber cloth (or soft COTTON).
However, if the problem does not disappear, please check with SONY support (there may be dust UNDER the back panel - thus not user cleanable). Your phone should have warranty, so go and check it out!
