Hi I just bought this phone last tuesday when I came to use it the estimated battery time is 2 Days when not in stamina mode and I think 4 days in stamina.. after just a day the estimated battery time changed.. I tried also using PCC factory reseting my phone at start up the estimated battery time is 2 Days when not in stamina mode and I think 4 days in stamina..
Is this normal?.. please see attachment below..
This attachment is Stamina mode is not yet activated
This attachement is Stamina Mode is activated
The phone learns from your usage, and sets a new estimate according to how much battery you consume, then extrapolate the consumption data to gime you a more accurate estimate. Check "Battery usage" on the same settings page for more information.
Ah so it adjust based on my current setup on my phone?..
Yes, I have a Z3D and it's also advertised as 2-days battery capable, on my usage it lasts for 1.5 days.
Cool now I don't have to go to the service center.. thanks a lot man for your reply
No problem.
