Dear Gents,
I am desperately looking for advice how to revert my display settings without restore. I was unofrtuntately lazy so I did not do backup frequently.
My problem is that I played with display settings and I enabled some experimental feature.
Now my display's fonts are blurry and not sharp. There are same strange arftefacts sorrounding icons, fonts.
There should not be any HW problem.
In past I solved similiar problem by restoring of settings but for now I would like to get rid this procedure due to reason above.
Any advice is welcomed!
Regards
Andy
Sorry sir,
what I remeber was display settings with some experimental feature. But for now I can not find this settings in menu.
Do not you have idea where to find it?
Regards
All right Sir. I switched off High contrast text as experimental feature under Settings> accessibility and it is gone!!!
Now iconcs are crystal clear and no artefacts on display!
It has saved me lot of headachces sir!
Anyway I want to revert back setting is is possible just to make such selective restore from backup?
Regards
I'm not sure if you can backup accessibility settings
