@Ettiene13
If you removed the SD card you will have to redownload the app.
You can't, the icon will be replaced by the app icon once you reinstall it.
@Ettiene13 You should be able to remove the icon by clearing data for xperia home app under settings-apps-all. Anyway, thread locked.
