I only intend to use cm launcher until my problems are fixed. I also didn't like that they removed the Cameras widget. And that the icon group boxes/folders as well as the all apps navigation button on the home screen are now displayed in opaque. I want the transparent ones. Those in the lollipop home screen.Hi @FireXCross,
Welcome to the community.
I am sorry to hear about these issues you are having since updating to Marshmallow.
It is possible that some of the apps you have on your device are not up-to-date or not compatible with Marshmallow, as a first step I recommend you make sure all your apps are up to date with the latest versions.
If this doesn't work, you should re-install the update by performing a software repair.
If you are posting from your mobile, you will need to switch to the full version of the website to attach images, there is a link at the bottom of the page.
