Hi @schkr, I'm sorry to hear about that.
Do you have time and date set to automatic, or have you entered it manually? To check that, go to Settings > Date & time. If you have it set to automatic, try to see if it makes a difference in manual - and vice versa.
In addition, could you try clearing data for the clock app? This will reset all your alarms and other clock settings, but may help solve what you're experiencing if the cause is the app itself. Go to Settings > Apps > Clock > Storage > Clear data in order to do so.
Let me know how it went!
Yes, feel free to let me know how it went! Regarding STAMINA, the Alarm should still be present while in the STAMINA/Ultra STAMINA modes so it would sound strange if these were the cause. Could you try to see if the same occurs in safe mode if it persist even after clearing data?
I have same problem. The problems started after the upgrade android 6.0. I've tried different alarm applications but problem is not solved.
I have the same problem guys ..
Android 6 (30.2.A.1.21) bug , please sony fix this
That sounds very strange.
I would like to forward this internally for investigations, could one of you create a bug report and send it to me by PM?
To create a bug report, go to Settings > About phone, tap the build number until it states that you're a developer. Once that is done, go to Settings > Developer options, activate USB debugging here and change the logger buffer size to 4M.
Now wait for the alarm to be delayed, then go to Settings > Developer options > Take bug report > Report. A file will now be created and you can follow the progress in the notification bar at the top. Once it's done, choose to share it to for example Dropbox or Google Drive and then send me the link in a PM. Make sure the file is set to public so that I can access it.
When I have stamina mode on
Some times the alarm clock delay ... e.x I set to ring at 4:00 pm and rung at 4:05 pm
I tried to take a bug but when I open the screen the alarm clock start to ring
How to sent the bug ?
After the alarm ?
Hi @Georges98,
Yes, after the alarm has rung simply follow the steps I mentioned in my previous post to create the bug report. Once it's done, you'll see it in the notification bar and by pressing it you should be presented with options for sharing it. Share it to a cloud based storage and PM me the link to it.
Also, please include step by step instructions on how to recreate the behaviour.
