My lens doesn't focus when I'm not at the 16mm end of the zoom range. As soon as I zoom in it makes clunking noises and goes out of focus. See https://www.youtube.com/watch?v=uPHXo4CqS2E&feature=youtu.be
That's not normal!
You probably need a repair...
That's what I figured. I have taken a closer look now that I'm home and the lens element closest to the bajonet is loose. How? I have no idea. Any tips where I can get this repaired?
The easiest way is to bring it back to the shop where you bought it from.
I bought it in the USA
Woon je in België of Nederland? In principe zou je in elke winkel (tegen betaling) een lens moeten kunnen laten herstellen of rechtstreeks Sony bellen voor verdere instructies wat betreft een reparatie.
Ik ken deze gegevens niet vanbuiten, iemand anders? Staat wellicht ook op de Sony website.
If living in Belgium, nowadays, this is an excellent place to get Sony stuff repaired (phones excluded) :
http://www.scd.be/ (Service Center Deinze)
Good luck.
