Hello,
my xperia L1 did suddenlyturn off and is unable to be turned on back again.
I tried all possible key combinations - power off + volume up/down.
I left it on charger for 2 days, and nothing helps. I have no SD card.
Also when it is on charger the LEd does blink red light on and off.
I connected to PC companion, and had it on for like 20 minutes trying to attempt a repair and nothing happened, it still just found some modem device and it disappeared quickly after that.
Any ideas?
Thanks
Regards
Hi @Halibaba, let me see if I can help out here!
Just to be clear, did you use PC Companion to repair the software or Xperia Companion? PC companion is our old program and will not work, I am afraid. Xperia Companion is free to download and you can find it here.
In addition to what you mentioned regarding not having a SD card, It could also be a good idea to try to start the phone without the SIM card in order to see if the SIM card is malfunctioning. If that does not work and if you are not able to repair the software, I would suggest that you get in contact with your local support team for further instructions on how to have your phone sent to an authorized service center.
Let me know if that helped!
