I need some help my Phone Xperia l1 us restarting without permisions when I use any aplications, is there any solution to this? Can you help me please?
The Phone it restarts without any reason I am Just using an aplication and then the restarts itself.
The Phone restarts without any reason, I use any app and then suddenly restarts itself, and I do not know what is the reason the Phone restarts itself. I use every aplication and then it restarts
The Phone restarts itself when it uses any aplication
Does it happen when using any application? Well, this is the possible reason: the internal memory is corrupted or the storage space is almost full. There are two solutions to repair Android keeps restarting:
1. Delete the app in safe mode
Turn off the device <press and hold the power button until the logo appears <release the power button, but press and hold the volume down button until the phone starts < delete the application in safe mode <restart the phone to exit safe mode.
2. Clear cached data
Turn off the power <Also press and hold the volume up, home and power button <After the vibration, just release the power button, but press and hold the other two buttons until the Android System Recovery screen appears <Use the volume button to select "Erase the cache partition". Confirm this with the power button <The phone will automatically restart.
