I have a proproblem, some times wheaniIplug in my l1, the lilight itsi on but it won't charge and the notifinotific lite stays on when when i use the phone
Hi @Arthur198, welcome to our forum and I'm sorry to hear about this.
Do I understand correctly that the LED light is still on even when you unplug the charger from your device, but the device is never charging? If that is the case, does the device charge if you turn it off and connect the original cable and charger to the device?
If you haven't tried charging the device using a USB port and only the cable, I would recommend doing so.
Let me know how it goes!
