When ever I try to connect to the wify in my office the wify does not connect at all.
tried restarting the device, tired in safe mode and nothing works.
when I do not connect to the wify provided by my office the signal streangth shows as excellent and the moment I connect the signal streangth goes to poor.
Please help me on this
Thanks,
Praveen
Hi kohir2
>try removing all wifi networks on the phone using forget network, later restart the phone
>try adding your office network as first, try to connect now
Let us know
Manjuboyz
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks
You can also take a look at the follow topic:
http://talk.sonymobile.com/t5/FAQ/Wi-Fi-problems/m-p/348104#U348104
Thanks a lot Buddy.
it did work now.
my only concern if this is a one time issue or I will face this again
Thanks,
Praveen
Hi kohir2
nice to hear, that it is working, try hard reset once , i guess that may fix any issues
take care:)
Manjuboyz
NOTE:
