please help me out
i tried the xperia diadnostics on fixing my xperia l sound issue and fortunately it worked. thanks!
I am using SONY ERRICSSON from last 5 years, which forced me to fall in love with that model.
But recently I purchsed SONY brand which is fully disappointing model
It is less than a month I encountered loud speaker problem, when i visited service center they asked me to surrender my mobile for 8 days which i cannot afford.
It is very disappointing, cheap service. Henceforth i will never recommend SONY to anyone, it seems that SAMSUNG, HTC and iphone is really better.
how can i resolve my sound issues.My main speaker just stopped working this is the second time it happened and it's not even been two days since i used my phone pls pls help
after update xperia L there is a sound problem. the problem is that when i start music sound came from internal speaker not from external speaker.. how it solved?
Yap i have the same problem here
When i restart the phone its ok but after a phone call i have the same bug my message tone dont work my phone turns silence mode only vibrates.
Any soluction to this bug?
I also have nearabout same kind of problem, my L speaker works while Ringtone and notification, alarms.
But doesent work for Music. That sures that it is not any Hardware problem with handset.
And one more problem is Internal earphone doesn't properly,
when I said properly it meaning that, sometime it works and sometime doesn't work.
Mainly when I switch to the L speaker, it works and back switching to internal speaker it doesn't work.
I can't hear sound in the internal speaker anyhow.
It might be again concluded that it is not a hardware problem.
I think it is the problem with software interfacing with Android and Hardware of Sony Xperia L,
I have upgraded my mobile Android version to 4.2.2, but it couldn't be the problem because it was working.
Near about over more than one month it was worknig. And then now mobile speakers are facing such problem.,
As I found on this site, I didn't found any solution yet which can cure this problem,
Please suggest any solution, may be setting problem, so that I can change my settings.
Or may be software updates, or driver reconfiguration, etc. that I can do myself.
Thanking all in advance.
