I am using Xperia L, it's good but I am facing some problebs while using
1)I cleard cache through optimise master,After that I am unable to see media album photos_it showing black screen.so what I have to do?
2)while playing game it's getting henging.
3) low
battery pickup?
if that doesn't help try this
settings > apps > all > album > clear everything > restart your phone
on 2) if you meant to say that the phone slow down, that's normal if the game is too heavy cpu/ram demanding
3) elaborate on battery life
settings > power management > battery use
take screenshots of
1) the whole list
2) tap on the graph and take a screenshot
3) tap on the top 3 items and take a screenshot of each
post them all here
screenshot = press and hold at the SAME time power & volume down
Please suggest me
you do not need
taskillers
task managers
antivirus
ram apps
battery apps
booster apps
uninstall them > restart your phone
take screenshots of
1) the whole list
post them all here
