my xperia L will turn off automatically,when i turned on its wifi.how to fix it????
close wifi and don't start
I think there are too many restart problem about xperia. radio chip may be weak
if not sony will answer the problem with real couse.
GMu you should turn on Gps (GPS satellites ) then tell me
when i put turn off the gps and using airtel sim it works properly without restarting but when i put docomo sim without gps on it restarting....but when i put turn on gps it works with docomo sim also...now its not restarting..it works perfectly...
