Is it possible to change the data usage dates used to monitor data traffic. My L2 allows you to do this when you check mobile data traffic but the dates under WiFi seem fixed. My data plan changes on the 1st of each month but Wi-Fi data usage tracks it from mid month to mid month meaning you can't really see how much data you are using. Hope I've explained this properly.
Hi @Rocktrip, welcome to our forum!
I'm afraid that there is no setting to change the dates for Wi-Fi usage, this is only available for mobile data usage.
Do you have a 4G router and the data plan you have it used for both the phone and the router? If that is the case and you need to know the exact amount of data used each month there should be applications available in the Google Play store that tracks data usage for both Wi-Fi and mobile data between certain dates.
The operator that I use has an application where I can see how much data I have used for the month, so your operator may have something similar that you can use get a better overview of your data usage, both for Wi-Fi and mobile data.
I hope that helps!
Hi Jonas
Thanks very much for the advice. I'll look into it
All the best
Andy
Hi again @Rocktrip, you're very welcome!
Have a nice day and feel free to let me know if you find any application that you like.
