Hi
my husband has only had his Xperia L3 4 weeks and dropped it in a puddle. It will no longer work. Are we able to fix it?
thank you
Hi @Krailton, I am very sorry to hear about this.
So if I understand you correctly, the phone is not able to start up at all after the accident? In that case, I believe that the best thing to do is to have the phone physically examined by an authorized service technician. And due to the fact that service routines, warranty and consumer laws varies depending on where you are located, I would suggest that you get in contact with your local support team for further instructions in the matter.
I hope that helped a little bit on the way!
