Alguien sabe como quitar la vibración de los botones de atras de ir a la pantalla de inicio... (los tres que hay en la parte de abajo) esque me molesta bastante.
Y también cuándo bajas el volumen en vez de quitar el sonido lo pone en vibración alguien sabe como simplemente quitar el sonido sin la vibración
Anyone know how to remove the vibration of the back buttons to go to the home screen ... (the three that are at the bottom) esque bothers me a lot.
And also when you turn down the volume instead of removing the sound puts it into vibration, someone knows how to simply remove the sound without the vibration. - GT
Hi @Natxo1, let me see if I can help out here!
I have translated your question to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
There is no way to remove the vibrative response that occurs when turning down the volume. This due to the fact that this vibration is supposed to indicate that the phone is set to vibrate on incoming calls. However, it is possible to remove the vibration of the navigation keys. To do this, find and tap Settings > Sound > Other sounds > Deactivate "Vibrate on tap".
I hope that helped, let me know if you have any further questions!
