How do you turn on Java script and why is it not turned on as standard?
Hi @weegieschemie,
You can enable JavaScript for Chrome if you go to: Chrome > Tap ... > Settings > Site settings > JavaScript > On.
I hope this answers your question.
If it helps: It was on by default on mine.
Go on settings, search "default" .
Go to default apps and click on opening links.
Scroll down to 'Setup Wizard' and enter. There should be a little exclamation mark, click on it. Disable the app. Make sure your preferable default browser has javascript enabled though. Yours apps should work properly now.
