Hello there, i have xperia L2 and weeks ago and till this very moment some unkown ads pop up when i am using any social app or playing games, how can i solve this and stop it?
most likely it's an app acting up, you will have to uninstall one by one until you find the culprit.
Hi @fanta89, welcome to our forum!
Ads are always coming from either a download application or from an open website in the background, however if they only occur when using certain applications, it sounds like you have downloaded an application that pushes ads to your device.
They only solution is to find which application is sending the ads and a good place to start is by opening up the Google Play store > tap the three lines in the top right corner > My apps and games > Installed > and sort by "Last updated".
I hope that helps!
